88 uses a separate TCU, whereas I believe in 2000 it is incorporated into the ECU. The 2000 transmission has more sensors that the 88 computer does not need, and the wiring harness is different. If you can adapt the harness, I see no reason why it should not work, but can't guarantee it.
  • 1 month later...
Switch the sensors you need to the new trans. AFAIK, they should all work (I put a '98ish one in mine) Just make sure you have the right tcase for the trans. The swirled the splines right about then.
