I have heard of some guys having luck with deep cleaning since the electricity sometimes will release the gunk from the metal. I have also heard of guys using lye mixed in or soaking their parts in farm grade vinegar? Both are caustic so I have never tried them.
  • 4 weeks later...
Good video. I'd done quite a bit of it recently on my two old CJ3As. Depending on how much juice you pump through the solution it will take just about everything off, paint, gunk, rust, everything except the metal.
Vinegar will work also but much slower, I keep a gallon of it and toss small parts, bolts etc in it. Diluted Molasses also does the job, I believe it forms a phosphate, the common ingredient in off the shelf rust removal products.
There is an australia guy with some you tube videos restoring classic cars and he goes into the mollassas process. Takes a while but will remove all rust inside of doors and frames where you cannot get. Very cool stuff!
