goatroper57 Posted January 14, 2012 Share Posted January 14, 2012 hello all i was wanting to know can any one tell me what carburator kit i need for my 1986 jeep comanche xls the motor is a 2.8 i really don't know what to look for so can any one help please Link to comment Share on other sites More sharing options...
jimoshel Posted January 15, 2012 Share Posted January 15, 2012 You will have either a E2SE for LaLa Land or a 2SE for the other 49 and Canada. There should be a tag on the carb. Link to comment Share on other sites More sharing options...
cz777 Posted January 15, 2012 Share Posted January 15, 2012 them fairy jet carbs suxs !!! look in the a Weber carb kit and mod it in .....yes it maybe some work to do this but they work ! Link to comment Share on other sites More sharing options...
goatroper57 Posted January 15, 2012 Author Share Posted January 15, 2012 ok thank you jimoshel ill have to look on the carb then but i was talking to a buddy thats a pritty good michanic and he said with out lookin at it it sounds like the chock just need ajusting where can i get a free guide on how to ajust it or dose any one have a copy that i could get from them as i ant got the money to buy a manual and the wife needs the jeep for work she drives about 90 miles a day 7 days a week thanks all Link to comment Share on other sites More sharing options...
jimoshel Posted January 16, 2012 Share Posted January 16, 2012 A simple check. Remove the air intake hose from the top of the carb. Do this while the engine is cold, before you start it. Look down into the carb bore. The choke plate should be closed. Now start the engine. The plate should open. Depending on the outside air temperature will affect how much the plate opens.If it's warm out and the engine gets warm it should be fully open. Also , there's a timer in the circuit. After so many hours it kicks in and does something to the carb. Don't remember what. Have to look it up. Also check the EGR valve. If it's not working properly it has some of the same symptoms as a bad choke. Auto Zone has some pretty good repair guides on it's site. Look up AutoZone. Register, type in the vehicle info and see what it comes up with. Link to comment Share on other sites More sharing options...
goatroper57 Posted January 16, 2012 Author Share Posted January 16, 2012 ok ill check it out would it be best to check it when its cold or warm outand as far as buyin the book we ant got the extra money right now to spend Link to comment Share on other sites More sharing options...
jimoshel Posted January 16, 2012 Share Posted January 16, 2012 They're not hard print manuals. They're on line tech info. All you need is a puter. Link to comment Share on other sites More sharing options...
