Engine dies on deceleration
We have cleaned the throttle body and have done the following: crank sensor, stator, idle air control motor, oxygen sensor, EGR solenoid (we cleaned the EGR valve), ignition wires, plugs, distributor cap and rotor and fuel filter. In addition I've replaced the muffler, heater core, blower, resistor, oil pan gasket, rear main seal, PVC assembly, vacuum harness and battery. Do you think an EGR valve can appear to work but not actually be working... Needing to be replaced?
TESTING THE EGR VALVE FOR 87-90 4.0 ENGINE
Valve Opening Test
1) With engine at normal operating temperature and at idle,
rapidly open and close throttle. Open throttle sufficiently to obtain
at least 1500 RPM. Movement should be noticed in EGR diaphragm.
2) If diaphragm does not move, probable causes are: faulty
vacuum signal to EGR, defective EGR diaphragm or defective
backpressure sensor diaphragm (if equipped), or leaks in vacuum lines
or connections.
Valve Closing Test
manually depress EGR valve diaphragm. RPM should immediately drop,
indicating that EGR valve is not leaking and had been properly cutting
off exhaust gas flow at idle.
2) If there is no change in RPM and engine is idling
properly, exhaust gases are not reaching combustion chamber. Check for
plugged passage between EGR valve and intake manifold.
3) If engine idles poorly and RPM is not greatly affected by
manually moving diaphragm up, EGR valve is not closing off exhaust gas
flow. Check for carbon between pintle, leaking EGR valve gasket or bad
EGR valve.
