brubakes Posted January 8, 2012 Share Posted January 8, 2012 Is the 8.25 rear axle from a 97+ XJ a direct bolt into a MJ? Link to comment Share on other sites More sharing options...
SW86 Posted January 8, 2012 Share Posted January 8, 2012 no. there is no direct bolt in except from another MJ. Link to comment Share on other sites More sharing options...
brubakes Posted January 8, 2012 Author Share Posted January 8, 2012 no. there is no direct bolt in except from another MJ. How close is it? Just moving the spring perches? Link to comment Share on other sites More sharing options...
mvusse Posted January 8, 2012 Share Posted January 8, 2012 Pretty much, yes. Cut off the spring perches and shock mounts, then have new spring perches welded on in the correct location. You can do the cutting yourself with an angle grinder and a cutting disk. After that use a grinding disk to clean it up and remove all rust and grease to show shiny metal (needed for a clean weld). Then have someone with a large welder burn the new perches on. If you have a buddy who can do it it might cost you a six pack. I had a local welding shop do it for $20. If you are staying spring under, stock perches from Mopar or Summit Racing (the 8.25" tubes are the same diameter as a Ford 9") will work fine. If you're going SOA I suggest longer perches, such as those made by http://www.ruffstuffspecialties.com Link to comment Share on other sites More sharing options...
brubakes Posted January 8, 2012 Author Share Posted January 8, 2012 Thanks mvusse. I guess maybe if you have to swap perches anyway an 8.8 would be a better choice. Link to comment Share on other sites More sharing options...
mvusse Posted January 8, 2012 Share Posted January 8, 2012 Be aware the 8.8 is an inch narrower. Not a big deal for Cherokees and Wranglers, but in Comanches it can cause problems between the tire and the inside of the wheel wells, so you have to run wheel spacers or wheels with less backspacing. Not to mention adapting either the pinion yoke or the driveshaft to hook up to each other and adapting the parking brake cables. Link to comment Share on other sites More sharing options...
terrawombat Posted January 8, 2012 Share Posted January 8, 2012 If you're going to be doing a decent amount of off-roading, I would go with the 8.8. Link to comment Share on other sites More sharing options...
mvusse Posted January 8, 2012 Share Posted January 8, 2012 I have mercilessly abused my 8.25" with a locker and 35" tires for almost three years now with never a problem. That includes doing a rear wheel stand bouncing under full throttle trying to climb a steep rocky ledge. Although that one stint cost me a rear driveshaft. Breaking a 29 spline 8.25" takes larger than 35" tires, more weight than a Comanche and/or more power than the 4.0 puts out. Link to comment Share on other sites More sharing options...
89Comanche4x4 Posted January 9, 2012 Share Posted January 9, 2012 i recently put a 8.25 under my truck, cut off thee shock mounts, made some new ones. cut off the perchs and re used them, it was pretty simple actually. and the driveshaft bolted right up Link to comment Share on other sites More sharing options...
