brubakes Posted January 5, 2012 Posted January 5, 2012 What all is needed to pull the older CAD front axle and put in a HP D30 from a 97-99 XJ?
Geonovast Posted January 5, 2012 Posted January 5, 2012 A jack, jack stands, and a good set of sockets.
brubakes Posted January 5, 2012 Author Posted January 5, 2012 A jack, jack stands, and a good set of sockets. Direct out with the old in with the new? Nothing special?
Geonovast Posted January 5, 2012 Posted January 5, 2012 Pretty much, yeah. Worst part is bleeding the calipers, because chances are you're changing brake generations. Nothing fancy to it at all. All XJ/MJ/ZJ/TJ Dana 30s are interchangeable. If you don't have any stubborn bolts you should be done in a couple hours.
Pete M Posted January 5, 2012 Posted January 5, 2012 and plugging a vacuum line so you don't have a leak. :thumbsup: I assume you've matched the gear ratio with the rear axle?
bighause Posted January 5, 2012 Posted January 5, 2012 The bolts on the upper control arms are torx bolts so make sure you have a set of torx bits. I've done this and it's pretty straight forward. Sometimes getting the control arm bolts lined up is a bear but a ratchet strap to pull it into place works great.
Blue88Comanche Posted January 5, 2012 Posted January 5, 2012 The bolts on the upper control arms are torx bolts so make sure you have a set of torx bits. I've done this and it's pretty straight forward. Sometimes getting the control arm bolts lined up is a bear but a ratchet strap to pull it into place works great. I have done that, but it was a pain to do... all i did was remove the lowers mo make it easier to install new springs and spacers.. when i swap my D30 for a non cad, will it be easier to attach the upper or lower control arms first?
Pete M Posted January 5, 2012 Posted January 5, 2012 I went uppers then lowers. used a crowbar to pry the axle over a half inch for the last bolt. wish I had thought of using a ratchet strap. :doh:
dakal Posted January 5, 2012 Posted January 5, 2012 how about a pipe wrench and floor jack. works great :yes: :bowdown:
brubakes Posted January 7, 2012 Author Posted January 7, 2012 The reason I ask if if your putting a 242 into a MJ and want want to do away with the CAD as a whole so it won't destroy the case.
