Whats involved with pulling the CAD D30 with a later HPD30
Pretty much, yeah. Worst part is bleeding the calipers, because chances are you're changing brake generations.
Nothing fancy to it at all. All XJ/MJ/ZJ/TJ Dana 30s are interchangeable. If you don't have any stubborn bolts you should be done in a couple hours.
The bolts on the upper control arms are torx bolts so make sure you have a set of torx bits.
I've done this and it's pretty straight forward. Sometimes getting the control arm bolts lined up is a bear but a ratchet strap to pull it into place works great.
I have done that, but it was a pain to do... all i did was remove the lowers mo make it easier to install new springs and spacers.. when i swap my D30 for a non cad, will it be easier to attach the upper or lower control arms first?
