rokcrwler Posted December 14, 2011 Share Posted December 14, 2011 So my fuel gauge went crazy (way past full) the other day. So I pulled the dash apart and cleaned the connection plug that goes into the back of the cluster and it worked for a month or so.. I did it again and this time it only stays correct until I turn the key off and back on..? Even if I just wiggle the connection itll read accurate only until I turn the key off to back on. Any Ideas? Thanks Link to comment Share on other sites More sharing options...
jimoshel Posted December 15, 2011 Share Posted December 15, 2011 Loose, broken wire going from the wiring harness to the plug? Don't think you can reach it from under the dash, may have to pull the cluster a bit. With the ign sw on, wiggle the wiring harness-connector. See what the needle does. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 15, 2011 Share Posted December 15, 2011 Your comanche should be parked in a climate controlled garage right now!! If you cannot figure out whats going on, I have a different cluster or two that you could try. Link to comment Share on other sites More sharing options...
rokcrwler Posted December 19, 2011 Author Share Posted December 19, 2011 If I unplug the connecter from the cluster and plug it back in, its good untill I turn the key off and back on. I'm not sure why it would loose power after that?? Even just wiggling the connecter it won't work right again untill I unplug it.. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 19, 2011 Share Posted December 19, 2011 I'll be the signal from the sender is weak.......too weak to hold a constant reading. I have a XJ and the oil pressure gauge was acting in a similar way and I thought for sure it was the gauge until I tried another sender and it works fine now. Link to comment Share on other sites More sharing options...
JeffN Posted December 19, 2011 Share Posted December 19, 2011 full reading is usually a ground problem Link to comment Share on other sites More sharing options...
rokcrwler Posted December 22, 2011 Author Share Posted December 22, 2011 What ground? on the tank? the sender? or on the cluster? -or- Do I just replace the sender? If I change the sender, will I be able to get it from the parts store? or?? Thanks for all the help Link to comment Share on other sites More sharing options...
rokcrwler Posted January 5, 2012 Author Share Posted January 5, 2012 Still curious as to which ground I should be looking at? Or adding?? Link to comment Share on other sites More sharing options...
