jons87mj Posted December 4, 2011 Share Posted December 4, 2011 my 88 4.0 auto 4wd back fires atleast 1 aday and i don't know why :dunno: any help would be apprchated Link to comment Share on other sites More sharing options...
Eagle Posted December 4, 2011 Share Posted December 4, 2011 How old is the oxygen sensor? If it's old, it doesn't respond as quickly as it should to changes in the fuel/air mixture. When you let off the throttle, it allows too much gas to keep flowing, the engine doesn't burn it, so it does down the exhaust and burns in the catalytic converter. Backfire. Link to comment Share on other sites More sharing options...
jons87mj Posted December 4, 2011 Author Share Posted December 4, 2011 thanks ill just get a new one because the one thats in it came on the truck Link to comment Share on other sites More sharing options...
JeffN Posted December 4, 2011 Share Posted December 4, 2011 low fuel pressure can cause it to go real lean and detonate and that is very bad Link to comment Share on other sites More sharing options...
airspeed Posted December 4, 2011 Share Posted December 4, 2011 My sons 96 4.0 had an incredible back fire from a cracked exhaust header, this wasn't a little pop, we are talking a major ka-boom. Cars would pull over to the side of the road and people would come out of their houses. The crack was just above the O2 sensor so it must have been tricking the O2 sensor into a lean condition and dumping too much fuel. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 5, 2011 Share Posted December 5, 2011 WHEN does it backfire? On the gas, off the gas, idling? Link to comment Share on other sites More sharing options...
jons87mj Posted December 5, 2011 Author Share Posted December 5, 2011 It only does it when it does it right after you let of the gas Link to comment Share on other sites More sharing options...
