GAS TANK SOLUTION FOR A 4.0 CHEROKEE MOTOR SWAP TO A MJ
If you're swapping everything, you will need a different sending unit. Cherokee one will not fit in a stock Comanche tank because it is mirror image and the pan in the bottom of the tank gets in the way. Stores will tell you they sell Comanche ones, but they don't. They think Comanche and Cherokee interchange and don't know about the mirror image problem.
HOWEVER, a (the) Cherokee unit SHOULD fit inside an aftermarket Comanche tank WITHOUT the pan. Pay attention when ordering, because after market tanks are available both with and without pans.
If you're only swapping the block, keeping the Renix injection system and electronics, there is nothing wrong with using the sending unit and pump you have now.
  • 3 weeks later...
