kyleag89 Posted November 6, 2011 Posted November 6, 2011 The rear brake on the driver side locks up on me when adjusted properly. If I loosen the adjustment then the rear brakes have no power. Could the wheel bearing in the turdy five cause the drum to wobble and lock up the brakes?
carnuck Posted November 7, 2011 Posted November 7, 2011 Recheck the brake shoes are on the right way around.
Jerry Posted November 7, 2011 Posted November 7, 2011 Is the rear brake load sensor valve still in your system? Could it be that your passenger side rear brake is not working right or not adjusted right and because the proportioning valve is giving max pressure your driver side is locking?
