I know it's spelled wrong. I have a 1989 4.0l 5 speed, I need to change the transmission fluid, do we have a page to show this tran and specs on it? Thank you.
What do you need to know?
Don't believe the first gear spec everyone seems to use,
like 3.39:1, or something.
I've had 4 BA 10-5's,
the early 87-88's I had were ~4:1 first gear,
the 89's I had were ~3.75:1
When my 4wd 10-5 finally died,
I grabbed a 2wd 10-5,
swapped the 4wd output adapter in place of a 2wd's tailcone,
then cut the output shaft down to fit.
(2wd output shaft is splined all the way down to the speedo gear location).
The later 3.75 10-5's seemed more durable than the earlier 4:1's,
I changed the gear oil often, and extended the breather tube to keep the pukey from puking gear oil at highway speeds.
