pederl Posted October 26, 2011 Posted October 26, 2011 I know it's spelled wrong. I have a 1989 4.0l 5 speed, I need to change the transmission fluid, do we have a page to show this tran and specs on it? Thank you.
Blue88Comanche Posted October 26, 2011 Posted October 26, 2011 I just call it a BA/10, or junk.. the guys at a auto parts store should be able to tell you what you need.. sry i wasn't much help
jpnjim Posted October 27, 2011 Posted October 27, 2011 What do you need to know? Don't believe the first gear spec everyone seems to use, like 3.39:1, or something. I've had 4 BA 10-5's, the early 87-88's I had were ~4:1 first gear, the 89's I had were ~3.75:1 When my 4wd 10-5 finally died, I grabbed a 2wd 10-5, swapped the 4wd output adapter in place of a 2wd's tailcone, then cut the output shaft down to fit. (2wd output shaft is splined all the way down to the speedo gear location). The later 3.75 10-5's seemed more durable than the earlier 4:1's, I changed the gear oil often, and extended the breather tube to keep the pukey from puking gear oil at highway speeds.
