for you all who are running some sort of sub woofer using RCA cables.. how on earth did you get the RCA cable run from the dash? my radio bay is packed and can't find a way to get the RCA connectors through the dash. I would like to run the RCA cable as well as the remote turn on through the passenger side or under the center console.
thanks
I ran mine out through the bottom and along the bottom of the dash and in the inside of the plastic panels to the amp and under the carpet
Yea its a little packed back there, but can be done. bottom right corner is where i poked mine threw, then ziptied the cable under the dash over to the kick panel. can use a coat hanger from under the dash till it gets in the bay then tape the rca to the hanger and slowly pull it back out.
Just keep trying different things till you get it.
wait, don't you have some power wires that run down that side? you wanna keep all power wires away from RCAs as it can pick up interferance (SP?)
my power wires are on the drivers side
So i did remember right :D
I don't have a prob with interference in mine never had a prob with that and I have done serveral
Hmm ok, must not be much power, plus in a MJ theres only power to those wires when the door is open :rotf: If it works for you then :clapping:
err.. i mean my amp power wire is run on the drivers side, i don't have any power options on my MJ yet! lol
