johnny quest Posted October 15, 2011 Share Posted October 15, 2011 XJs and MJs are the same from the back of the door forward, including drivetrain, correct?? just about to pull the trigger on a crossmember built for an XJ, which has long arm brackets built in... Link to comment Share on other sites More sharing options...
Geonovast Posted October 15, 2011 Share Posted October 15, 2011 You're good to go. :thumbsup: Link to comment Share on other sites More sharing options...
Pete M Posted October 15, 2011 Share Posted October 15, 2011 sorta. the frames are actually a bit different and it'll depend on how that crossmember is designed and attached. :( Should be adaptable if nothing else. Link to comment Share on other sites More sharing options...
