Has anyone put the newer throttle body on the older style 4.0?? I would like to have the round mounting so i have more options for intake systems instead of the wierd 3 bolt rubber hose assembly that's on mine now.
Yes, but the intake ports won't line up properly. It will still function, and there are adapters out there for the sensors, but you might loose a few ponies. Also, the HO manifold doesn't have the hole for the EGR tube, so that will have to be properly blocked off and disabled.
