flint54 Posted September 29, 2011 Share Posted September 29, 2011 So, I'm going to check my toe-in using the "bungee cord with bar" method I saw around here somewhere (measuring and comparing side to side distances between front of tire and back of tire), and I'm now wondering if this should best be done with weight on wheels or weight off wheels? The wheel center is high enough that the bars are unaffected by bulge. Also hampered because I don't have a straight shot at the rear of tires - LCA's block that path. I may have to plumb (or framing square) down to the floor and measure there. Comments? Link to comment Share on other sites More sharing options...
ncm1 Posted September 30, 2011 Share Posted September 30, 2011 This may be a little too elementary, but all I did was use a tape measure in the back under the control arms and in the corresponding spot in the front. Once the two measurements were the same the deal was done. Link to comment Share on other sites More sharing options...
Geonovast Posted September 30, 2011 Share Posted September 30, 2011 Do not jack up the truck at all. Not by the frame, not by the axle. It must be sitting at driving stance. Link to comment Share on other sites More sharing options...
87Warrior Posted September 30, 2011 Share Posted September 30, 2011 I suspect you are referring to the method I posted, which is a slight variation from the recommended ORO alignment method. What I did:- Find two levels and bungee them to the center of outside of the wheel (set the levels so they are both 'level') - Measure the distance between the levels right at the tire tread - Repeat the measurement process for the front and rear of the tire - Adjust tie-rod so that the distance between the front and rear of the tires is 1/16-1/8 less than the rear Having a helper hold the tape will make this really easy if you don't have enough clearance at the back of the tire due to control arm or driveshaft interference. My method is a slight variation of the ORO method pictured below. I used the levels to make sure my measurements were taken at the same spot, front and rear of the tire. I have never tried this on a stock rig so I imagine there would be interference out back. As Correy mentioned above, you must keep the truck on the ground. You could use a plumb-bob to drop the rear measuring point further down, or you could clamp something like old wooden rulers (a square would work fine too) vertically to your level bungee'd to the wheel. However you go about it, make sure the the measurement point is the same for the front and rear. When I did it, I measured from the inside face of each level attached to the wheel. Link to comment Share on other sites More sharing options...
flint54 Posted September 30, 2011 Author Share Posted September 30, 2011 Thanks for the replies! Experimenter that I am, I've done the check with the axle lifted only enough to barely clear the tires from the floor and I've got it dialed to within 1/16" toe in. Tomorrow I will check it with full weight on wheels to see if and how much it changes. Will report back my findings. Weight on wheels makes best sense since that's how it's operated. Now then, using the angle table so prevalent, I measure 8 degrees caster. There are no driveability issues, and I'm inclined to do nothing rather than shim it back to the upper spec limit (LP D30) of 7 degrees. Am I missing anything? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 30, 2011 Share Posted September 30, 2011 Now then, using the angle table so prevalent, I measure 8 degrees caster. There are no driveability issues, and I'm inclined to do nothing rather than shim it back to the upper spec limit (LP D30) of 7 degrees. Am I missing anything? Not necessary to do anything, but in your case it's a simple matter to remove one of the thin shims (.95mm) behind each LCAs to get your caster spot on @ 7*. In my case after a 3" lift I had to insert one thick (4mm) shim behind the LCAs to get the caster back to 7*. Are you measuring caster with an angle finder on the ball joint flat? Link to comment Share on other sites More sharing options...
flint54 Posted October 1, 2011 Author Share Posted October 1, 2011 I'm measuring angle with a digital inclinometer on the round flat spots where the tubes abut the pumpkin. Get 86.1 degrees. Then, using the conversion table for LP diff, get 8 degrees. I think I should add shim to lower the angle, which would lengthen the LCA reach and rotate the diff forward, and reduce the lean of the caster line. Since it steers very smoothly and tracks straight, I'm inclined to leave it alone rather than adjust. My lift is only ~2 inches. Link to comment Share on other sites More sharing options...
