jcComanche86lb Posted September 28, 2011 Share Posted September 28, 2011 Hi, I have a chance to buy a Dana 44 front out of a 1978 ford for about a hundred bucks. The only problem is that it's missing axle shafts and locking hubs. Is this the type that PeteM adapted to his manche. And would it even be worth putting money into? If so would chevy shafts fit? Link to comment Share on other sites More sharing options...
xjrev10 Posted September 29, 2011 Share Posted September 29, 2011 It would be a HP 44. They are a bit wider then a stock Dana 30. It would be worth it IMO. Link to comment Share on other sites More sharing options...
mnkyboy Posted September 29, 2011 Share Posted September 29, 2011 78 has cast in C wedges so unless you want crappy Ford radius arms I don't think it would be worth it. Unless its from an F-150 extended cab or an F-250 then it could be leaf sprung and you could adapt a 3 or 4 link. Link to comment Share on other sites More sharing options...
xjrev10 Posted September 29, 2011 Share Posted September 29, 2011 78 has cast in C wedges so unless you want crappy Ford radius arms I don't think it would be worth it. Unless its from an F-150 extended cab or an F-250 then it could be leaf sprung and you could adapt a 3 or 4 link. got a pic of what you are talking about? not sure about them being "cast" in.. i got a LP44 out of a Bronco, the wedges are held on by 2, 3/8"X3 fillet welds...... Link to comment Share on other sites More sharing options...
mnkyboy Posted September 29, 2011 Share Posted September 29, 2011 I could snap a pic,I've got a few laying around. The earlier axles where weld on but 78 -79 they cast them in,it takes a retube to delete them. Link to comment Share on other sites More sharing options...
Motion Offroad Posted September 29, 2011 Share Posted September 29, 2011 It really depends on what it's out of during the '78-'79 time. '77-'79 F-150 Super Cabs and '78-'79 F-250's were setup leaf spring and did not have the cast wedges. The F-250 are going to be a 8 lug axle. If it's a '78-'79 axle setup for coil springs (F-100 or F-150 standard) it'll have the cast wedges. Link to comment Share on other sites More sharing options...
xjrev10 Posted September 29, 2011 Share Posted September 29, 2011 It really depends on what it's out of during the '78-'79 time. '77-'79 F-150 Super Cabs and '78-'79 F-250's were setup leaf spring and did not have the cast wedges. The F-250 are going to be a 8 lug axle. If it's a '78-'79 axle setup for coil springs (F-100 or F-150 standard) it'll have the cast wedges. Cool. Learn something new everyday :thumbsup: Link to comment Share on other sites More sharing options...
mnkyboy Posted September 29, 2011 Share Posted September 29, 2011 He beat me too it,I snapped some pics on my way out. Link to comment Share on other sites More sharing options...
jcComanche86lb Posted September 29, 2011 Author Share Posted September 29, 2011 I know he said it has radius arms on it so that guarantees that it will have cast in wedges if it's actually out of a 78? I plan on using the radius arms set up so that really doesn't bother me but it would be nice to have the option. Are the axle shafts compatible with any other d44? Would there be another d44 that would provide stronger shafts or u-joints? Oh yeah, what axle would be a good match for the rear? Link to comment Share on other sites More sharing options...
mnkyboy Posted September 29, 2011 Share Posted September 29, 2011 If I was to do it I think I would buy a basket case ford truck or bronco and use both axles. Also those axles are about 6" wider then what you have now. On mine I think I'm gonna retube a 79 bronco D44 to waggy width and stay 4 link. I know a lot of people like their radius/Y link arms but IMO removing a 4 link to install them is silly. Link to comment Share on other sites More sharing options...
