JeepNewb Posted September 28, 2011 Share Posted September 28, 2011 Soo i just started having this issue the other night after i parked the mj then tried to drive it yesterday. The clutch pedal went almost to the floor before feeling any resistance therefore i can't shift into any gear so open the hood and check.........and all the fluid in the clutch reservoir is gone :eek:. Bought a bottle of dot 3 yesterday and just filled it up this morning but still having the same issue. Thoughts?? Link to comment Share on other sites More sharing options...
JeepNewb Posted September 28, 2011 Author Share Posted September 28, 2011 I'm guessing the system needs bleeding?? Link to comment Share on other sites More sharing options...
CGross Posted September 28, 2011 Share Posted September 28, 2011 If the reservoir was empty, the system sucked in air and would have the same problem. So yes, you need to bleed it. Link to comment Share on other sites More sharing options...
El Comanche Posted September 28, 2011 Share Posted September 28, 2011 Try to find where the leak is. Also check the peddle linkage.The weld gave way on mine. Gord Link to comment Share on other sites More sharing options...
