Caliper problem
btm24
I'm having a problem with the passenger side caliper. It was scraping the inside of the rim when going in reverse. I'm wondering if this is caused by there being a size difference in-between two wheel drive and four wheel drive brake calipers? Or what else could it be?
Thanks for any thoughts
Brandon
You may have a bad unit bearing assy. It might only rub in that direction if the bearing goes bad and tilts the opposite direction. I'm not sure I'm making any sense right now, but lif the wheel off the ground and wobble it form the 9-3 positions and the 12-6 positions. If you have wobble, especially form the 12-6 position, you need a new unit bearing. Good luck.
