pingpong Posted December 21, 2005 Posted December 21, 2005 As some of you know I am putting an exo and tube bed on my rig. I am doing the research part of the fuel cell thing now. Have any of you successfully done this? If so what tank and fuel pump did you use? I did a bunch of research over on Pirate, and kept coming up with the ES2000 for a pump, but according to info I pulled out of the napa store, it doesn't have enough fuel pressure. BTW there are 2 different pumps listed in the napa book for a 90 4.0. The Warbo, flows 18gph, at 65 psi, and the other is a Bosch that flows 45 GPH, at 90-110 psi :shock: So any help on this would be appreciated. Patrick
87manche Posted December 22, 2005 Posted December 22, 2005 do you want the pump in the tank? I've seen Holley electic fule pumps used on v8 EFI systems, so I would imagine that they would hold up to the I6. I know they have a number of inline pumps.
DirtyComanche Posted December 22, 2005 Posted December 22, 2005 You could use your stock pump, depending on the cell. Most however, won't allow it. There's a thread on pirate to make a TJ pump fit in a cell, though. And avoid mounting an aluminum cell by the 'ears' as you'll break all the welds. Straping it in place with something with a bit of give will prevent this.
pingpong Posted December 24, 2005 Author Posted December 24, 2005 I thought about using the stock pump, but do the fact that I don't want to "modify" a new tank to make it work. I have read a bunch of stiff on many boards, so I think I am going to go with the E2000, with a poly cell with foam, and the holley dual pick up system. Patrick
