87Chief Posted August 30, 2011 Posted August 30, 2011 I am looking for a gauge cluster for my MJ to swap for gauges, I want the RPM gauge and everything. I really want one from a 2.5L with 5 speed.. You can email me. littlemlittle@gmail.com Thanks! Mike
87Chief Posted September 6, 2011 Author Posted September 6, 2011 or one from an MJ with a tachometer...?
87Chief Posted September 9, 2011 Author Posted September 9, 2011 oops sorry. Sorry, I'm looking for one from a 2.5L so the rpm guage will be correct. Usually they read different if swapped from a dif size engine.
Geonovast Posted September 9, 2011 Posted September 9, 2011 oops sorry. Sorry, I'm looking for one from a 2.5L so the rpm guage will be correct. Usually they read different if swapped from a dif size engine. The Renix ones are adjustable via potentiometer on the back of the gauge.
87Chief Posted September 10, 2011 Author Posted September 10, 2011 Really? I never knew that. How would you?
Geonovast Posted September 10, 2011 Posted September 10, 2011 You just turn the adjuster until it reads correctly. I believe it's set up so that all the way one direction is for a 6, and the other direction is a 4, but it's best to check it against one of those laser tachs.
