nitroxsteve Posted August 26, 2011 Posted August 26, 2011 I need a Speedometer cable for an 88, 4WD. Thanks,
Overland Posted August 27, 2011 Posted August 27, 2011 This is two piece correct? I think i have my 88 XJ's cable in garage. Have a pic of what you need to compare to?
nitroxsteve Posted August 28, 2011 Author Posted August 28, 2011 This is two piece correct? I think i have my 88 XJ's cable in garage. Have a pic of what you need to compare to? I have a one piece from the trans all the way to to the dash. I think the two piece was for cruse controll that I don't have. I found a part number for an 89 cherokee thats the one piece but I'm not sre if it works on a 4WD or RWD or both. I will try to get some pictures and a length. Thanks, Steve
Jeep Driver Posted September 13, 2011 Posted September 13, 2011 Where did you find it? I need the same one.
nitroxsteve Posted September 15, 2011 Author Posted September 15, 2011 Where did you find it? I need the same one. I found It at Advance Auto Parts the part number I used was 03269. I had to use an 89 Cherokee to look it up for some reason they don't show it under an 88 Comanche or Cherokee. I have installed it and it fits fine.
Jeep Driver Posted September 15, 2011 Posted September 15, 2011 Where did you find it? I need the same one. I found It at Advance Auto Parts the part number I used was 03269. I had to use an 89 Cherokee to look it up for some reason they don't show it under an 88 Comanche or Cherokee. I have installed it and it fits fine. Thank you.
