4 cylinder/stick shift Dakota and other things.
Was in the local Pull-a-Part yesterday collecting parts to get my truck back on the road.
First off was a Durango steering box. First two Durangos I spotted had rack-and-pinion steering. Third one used a conventional steering box (which I got), but it uses just three holes to mount it, not four.
Then off to a ZJ to get two unit bearings and both sway bar links as I got tired of waiting for someone (not JeepcoMJ) to send me a pair he owes me after 6 months. I have since been to Chicago and Detroit without them, and decided I was NOT going to Columbus, GA unless I had a pair installed. No more swaying side to side at 75mph.
Also got another temp sender off a 90 XJ to see if the gauge in the Purple People Eater reading low is a sender problem or a gauge problem (or possibly wiring). Have not yet installed it as it's been raining all day today.
While browsing around I came across a 4 cylinder stick shift (1990) Dakota. Thinking I had found the holy grail of bellhousings I looked underneath only to find the familiar NP model tag we all see on out transfer cases. Turns out is has a NP A535 transmission. Aren't they supposed to have an AX15? Or is the bellhousing from this transmission interchangeable with that from an AX15?
Went to install the Durango steering box and hit a snafu. The aluminum spacer between the frame and steering box needs to be shimmed out about 1/8" to clear the larger diameter box. I got some 14 gauge 1/2x7/8 bushings and will JB weld two of them on each bolt tower. Gives me just over 1/8".
