Backroads Posted August 11, 2011 Share Posted August 11, 2011 I'm into the swap for taking out the BA10 and replacing with AX-15. My truck is an 88, the trans is an external slave from 96. I pretty much know what I'm doing here (i think HA :yes: ) The only issue I'm stuck at is this pilot bushing/bearing. I think my big downfall is other internet posters loose use of terms and not noting a difference. I see people talk about cj5 pilot bushing needing replaced in one thread, and pilot bearing replaced in another thread. So the crank bore with exisiting stock bearing/bushing combo, is too small to handle the input shaft of the later year model AX-15. SO Do I leave the existing BUSHING, and pop out the bearing. Or do I take both out and replace. And which part am I using to replace it? A CJ5 bushing (my initial thought) or the bearing. I'm looking on rockauto.com at the parts list and they have both listed as separate parts. If I made this more confusing than need be, I can reiterate. Or just tell me if this is correct. I need to remove BOTH stock bushing and bearing, and replace it with JUST the BUSHING from the cj5 haha. Thanks guys :wavey: Link to comment Share on other sites More sharing options...
danno Posted August 11, 2011 Share Posted August 11, 2011 When i did my external slave swap it necessitated a late model clutch assy which came with a pilot bearing for the larger late model input shaft. I had to go get one for my older small input shaft. I think the terms bearing and bushing mean a two part bearing or a one piece bushing and are interchangable Link to comment Share on other sites More sharing options...
Geonovast Posted August 11, 2011 Share Posted August 11, 2011 Your confusion is understandable. Vehicles don't use a bushing and a bearing.. they have one or the other. The 87-91 4.0s used a bearing that was pressed inside of a sleeve, which isn't a bushing. When you do your swap, you need to pull both out(they probably won't come out together). And replace them with the 74 CJ 304 bushing(or bearing) Link to comment Share on other sites More sharing options...
Backroads Posted August 12, 2011 Author Share Posted August 12, 2011 Geonovast... I looked at part numbers before and i see that the existing on is in fact a " ushing" with roller style internals making it all a bearing. But when i went to rock auto to get the bushing everyone mentions, they actually have a listing for EACH a bushing and a bearing. The diameters seem such that one fits inside the other. They werent expensive so i got both, That was what really through me off track. Link to comment Share on other sites More sharing options...
Rymanrph Posted August 12, 2011 Share Posted August 12, 2011 When I did the swap, I pulled out what to me seemed like a bearing and replaced it with what I would call a bushing. Link to comment Share on other sites More sharing options...
Backroads Posted August 12, 2011 Author Share Posted August 12, 2011 ^ sounds clear enough. I was partially assuming thats what everyone was doing, but I wanted to be sure because I sure don't wanna have to tear it all apart again because I wasn't paying enough attention. Thanks for all the help. Link to comment Share on other sites More sharing options...
Backroads Posted August 17, 2011 Author Share Posted August 17, 2011 So in case anyone else in the ax15 swap world wants to know... I ordered both the bushing and bearing rockauto lists for a 73 cj5 with a 304 v8 and even though they are 2 different part numbers and show different dimensions they are the SAME part in a different box and diff part number...... /mystery :) Link to comment Share on other sites More sharing options...
Backroads Posted August 17, 2011 Author Share Posted August 17, 2011 One last follow up question... Is this gonna sit flush w the end of the crank or stick out a little because its def longer than the original puegot bearing Link to comment Share on other sites More sharing options...
Backroads Posted August 17, 2011 Author Share Posted August 17, 2011 bueler? I wanna drop this clutch and I wanna be sure of this before I do that. I found another response in searching that said it fits but not flush, just wanted to see what everyone elses experience was. Link to comment Share on other sites More sharing options...
