86maroonmanche Posted August 11, 2011 Share Posted August 11, 2011 hey I'm i have a 86 comanche 2.8 long bed I'm putting on a tubular rugged ridge rear bumper replacing it from the stock one do i have to cut the original bumper mounts to install the new bumper to the actual frame? thanks Link to comment Share on other sites More sharing options...
jimoshel Posted August 11, 2011 Share Posted August 11, 2011 Doesn't the new bumper have mounts already on it? If it doesn't and your supposed to furnish your own then; 1, If your current bumper is stock and in good shape then don't cut it up. There are others who can use it. It's not that hard to fabricate a set of mounts. 2. If it is bent all to H*ll or rusted out, then cut the mother. Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 11, 2011 Author Share Posted August 11, 2011 the original bumper is off has a dent on the right side the corners are good I'm having problem with the new bumper mounting cause its shorter then the original and the new brackets have no where to go besides the flimsy sheet metal peice behind the original bumper and under the tailgate here is the bumper- and here is a close up of the dent- Link to comment Share on other sites More sharing options...
jimoshel Posted August 11, 2011 Share Posted August 11, 2011 Even with the dent that's a nicer bumper than many on the road now. Shame to cut it up.A bumper mounted to sheet metal is useless. Not worth the bother to put it on. Weren't there any instructions included? Link to comment Share on other sites More sharing options...
Eagle Posted August 11, 2011 Share Posted August 11, 2011 I'm not sure what's going on from your post -- you are aware that the factory bumper mounting brackets bolt to the frame rails, right? And that aftermarket bumpers typically require removing the factory brackets and bolting the new bumper to the frame using the same mounting points. How did you get the old bumper off if you didn't remove the factory mounting brackets? Universal brackets are available from Westin (Fey): http://westin.iwebcat.com/v5/Members/lo ... nting+Kit& Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 original mounting brackets were completly rotted and i got one of my friends fabricating me new ones for the tubular bumper because the new bumper hardware sits dead in the middle so i need a 1/4 inch thick roll pan basically so you don't see the undercarriage and that the bumper sits centered and straight and i still can have some where to put my license plate Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 and of anyone wants the bumper its free just got to come pick it up but i don't have hardware at all for it just the bumper Link to comment Share on other sites More sharing options...
Eagle Posted August 12, 2011 Share Posted August 12, 2011 and of anyone wants the bumper its free just got to come pick it up but i don't have hardware at all for it just the bumper What part of New York are you in? Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 long island nassau county Link to comment Share on other sites More sharing options...
MJCARENA Posted August 12, 2011 Share Posted August 12, 2011 I didn't know they made a rear bumper for the Comanche. Did you get one for a Cherokee, then you will have to adapt it for your truck. Any photos of the bumper and its mounts. Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 when i ordered it the site said it was for mj 86-92 comanches but i realized when i opened it it didnt "direct fit".......only came with what you see in the pic and it did come with 4 bolts too Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 here's the site once my friends done with the brackets i won't be so pissed at ordering from the site because there pretty cheap compared to others rearbumper http://thejeephut.com/tubular-rear-bump ... 29077.html frontbumper http://thejeephut.com/tubular-front-bum ... 29061.html Link to comment Share on other sites More sharing options...
MJCARENA Posted August 12, 2011 Share Posted August 12, 2011 You have to be careful and do research on parts for your truck. Alot of parts places sell Cherokee items and think they also fit our Comanches. Pretty much Cherokee parts fit from the cab foward, but from the bed back to the rear it's Comanche only (such as fuel tank/sender, axle, springs, bumpers) If you are not sure just post it up here and someone will let you know, These guys really know thier trucks. I have learned so much from this site. Link to comment Share on other sites More sharing options...
86maroonmanche Posted August 12, 2011 Author Share Posted August 12, 2011 yea i kind of figured that when i took the bumper out of the box but my friend said making a mount that'll go to the chassis will be easy then ill just tac weld it for extra support Link to comment Share on other sites More sharing options...
