rear Dana 44 question
Soooo, if I find a CL ad titled "Jeep Cherokee Dana 44!!! With Trac-Lock", I should probably go ahead and snag that huh? And what is necessary to do a swap, besides matching gear ratios, and spring perches?
Thanks.
How much are they asking for it. $200 or less would be a good deal. The Trac-lock is a limited slip that has clutch plates that wear out, but can be rebuilt.
Asking $240 and that's without the axle shafts...apparently they were removed for spares.
