Brenton Posted August 8, 2011 Share Posted August 8, 2011 I found a complete 94 XJ, 4x4, 4.0 5 speed that is being parted out. I would at least like the transmission for my 88 MJ. What all do I need to take from the Cherokee to make that work? And, is there anything else I should grab while I'm there? Is the rear end worth taking (assuming its the 8.25)? Thanks for all help/suggestions :bowdown: Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2011 Share Posted August 8, 2011 grab everything associated with the trans and inside the bellhousing: including the trans crossmember, shifter, bellhousing guts, and even the t-case (different input spline count). unless it's been altered from stock, the rear is a worthless 3.07 ratio. Link to comment Share on other sites More sharing options...
Brenton Posted August 8, 2011 Author Share Posted August 8, 2011 grab everything associated with the trans and inside the bellhousing: including the trans crossmember, shifter, bellhousing guts, and even the t-case (different input spline count).unless it's been altered from stock, the rear is a worthless 3.07 ratio. Thanks...hopefully I can get it all Link to comment Share on other sites More sharing options...
Brenton Posted August 8, 2011 Author Share Posted August 8, 2011 grab everything associated with the trans and inside the bellhousing: including the trans crossmember, shifter, bellhousing guts, and even the t-case (different input spline count).unless it's been altered from stock, the rear is a worthless 3.07 ratio. Is this a more or less bolt-on job, or is there some kind of fabricating or "customizing" that needs to be done? Link to comment Share on other sites More sharing options...
Pete M Posted August 8, 2011 Share Posted August 8, 2011 goes right in if rust doesn't get in your way. you will need a different pilot bearing/bushing, and the new crossmember goes in a different spot, but I'm told there are holes there already. the Ax-15 is the same length as the peugeot, so your driveshafts will still work as they do now. Link to comment Share on other sites More sharing options...
