jeepman 87 Posted August 1, 2011 Share Posted August 1, 2011 Need a caliper bracket for an 87-92 4x4 mj ( Dana 30 ) mine has a stripped out caliper bolt Link to comment Share on other sites More sharing options...
500 MJ Posted August 4, 2011 Share Posted August 4, 2011 a steering knuckle? Link to comment Share on other sites More sharing options...
jeepman 87 Posted August 4, 2011 Author Share Posted August 4, 2011 Whatever it's called, the part that the caliper hooks to Link to comment Share on other sites More sharing options...
mvusse Posted August 4, 2011 Share Posted August 4, 2011 The older ones use a caliper bracket that bolts to the steering knuckle. 91 and newer the caliper bolts to the knuckle itself. Link to comment Share on other sites More sharing options...
JeffN Posted August 4, 2011 Share Posted August 4, 2011 helicoil it Link to comment Share on other sites More sharing options...
jeepman 87 Posted August 5, 2011 Author Share Posted August 5, 2011 It's actualy on my 99 Cherokee but my 87 parts Comanche has the same part Link to comment Share on other sites More sharing options...
mvusse Posted August 5, 2011 Share Posted August 5, 2011 99 Cherokee the caliper should bolt directly to the steering knuckle. Changeover was ~91 IIRC. Link to comment Share on other sites More sharing options...
500 MJ Posted August 5, 2011 Share Posted August 5, 2011 What side? I might be able to help you out. Looking at getting a parts XJ this weekend. XJ was hit on the drivers front, Passenger side should be good. We'll see what the driver's side looks like when I get it... Link to comment Share on other sites More sharing options...
