somnus Posted July 30, 2011 Share Posted July 30, 2011 anybody have any idea why my 88 2wd is overheating the setup 88 lwb 2wd with 2 in budget boost and 31's with 3.55 converted cooling system to open last year newer style 2 core radiator removed heater valve and ran straight from waterpump to core and back electric fan wired to switch the problem on extended highway runs the temp gauge slowly climbs and does not stop climbing until i slow down below 60 mph. It does not matter if i turn on the electric fan or not. It does not overheat around town at all. this problem has been getting worse slowly over the last 3 months. I don't lose any coolant and can't smell antifreeze in the exhaust. mileage is slipping alittle but not bad. I am at a loss as to what could cause it to overheat at highway speeds and not around town. Link to comment Share on other sites More sharing options...
jeepsouth Posted July 30, 2011 Share Posted July 30, 2011 My cooling system will do the same when on the highway. I'm running an electric fan in place of the clutch fan ,original radiator, new thermostat,newer water pump installed by po. What gives? :dunno: Link to comment Share on other sites More sharing options...
zagscrawler Posted July 30, 2011 Share Posted July 30, 2011 I would suggest getting a thermal gun and run it on the hiway untill it starts to overheat a bit and pull over quickly and check the difference in temps at the head and the radiator, it might help you get an idea of where to start looking for answers. Also ive heard cases of water flowing to fast through the radiator to cool it properly, ussually because someone left out the thermostat. It could also be that your cooling system is working its butt off at all times and when your around town driving it has just enouph guts left in it to keep you cool under light load situations but when you get crankin on the hiway it puts the heat generated over the top of its abilities. something like a heavily deposited (hard water and such) block will keep water from flowing where it should and limit your cooling system. Just a couple things that crossed my mind. Good luck oh ya what motor? Link to comment Share on other sites More sharing options...
jeepsouth Posted July 30, 2011 Share Posted July 30, 2011 Makes sense,i'll try it. :cheers: Link to comment Share on other sites More sharing options...
Akula69 Posted July 30, 2011 Share Posted July 30, 2011 If you have replaced the lower radiator hose with an aftermarket one, the hose will collapse at highway speeds, restricting the water flow. The reason it collapses is due to the high suction in the system at those speeds. The origional AMC hoses had a spring inside to keep this from happening. I do not know if you can get an origional hose, the auto parts stores do have hoses that have an external spring, but I could not get it to bend enough to work. I ended up buying a hose meant for a chevrolet and pulling the spring out, then re-installing the spring into a "springless" bottom hose. My story is here: http://www.comancheclub.com/forums/viewtopic.php?f=2&t=25205 Link to comment Share on other sites More sharing options...
jeepsouth Posted July 30, 2011 Share Posted July 30, 2011 Good info ,and i have new hoses waiting in the garage ,but the lower one has no spring. :fs1: Link to comment Share on other sites More sharing options...
somnus Posted August 1, 2011 Author Share Posted August 1, 2011 i beleave i have the original hoses, will have to check that. Link to comment Share on other sites More sharing options...
