another pressure bottle post...
so my Blue Comanche has been sitting for a few weeks because the tranny was messed up... well the other day i went out to start up the engine because i did not want it to sit up too long, i let it run for about 10 - 20min with a few revs here and there and some constant throttle.. the electric fan was going and the hood was also up.. after i shut off the engine i noticed the bottle was full and started to leak water from the cap.. while the truck was running the bottle was about 1/2 full but filled up when shut off.
and because i can't figure out how to post youtube directly the the thread apparently the link is above where the clips should be...
thanks
That's normal. While the engine is running the coolant flows thru the radiator which cools it. When the engine is shut off the coolant picks up residual heat from the engine and expands. What is not normal is it leaking from the bottle. Either you had over filled it or you have a bad pressure cap ( gasket).
