Zoom By You Posted July 25, 2011 Share Posted July 25, 2011 I just purchased an ALL stock 1989 4.0 Comanche Pioneer. Being that the previous owner didn't know much about it; I requested a build sheet (included below) from Jeep. I wanted to see what 5-speed transmission I have in this vehicle. Well, I actually wanted to know if I had the BA10/5 transmission or the AX15. I received the build sheet and the transmission was listed as "DDX 5-Speed HD Manual Transmission" and when I did a search, it comes up with "DDX= 5-speed Manual (NVG 4500 HD)" which would be great but seems unlikely for that year. Any info would be welcomed....THANKS! Vehicle Description JEEP COMANCHE PIONEER Model Year 1989 Body Model MJ J M 62 Color PB3 Intense Blue Pearl Coat Build Date: January 11, 1989 Sales Code Description ADH Heavy Duty Electrical Group ADLP Skid Plate Group ALN Spring Special White Appearance Grp APAS Monotone Paint AWE Up Country Suspension Group BGAS Power Front Disc/Rear Drum Brakes BKPS 10x2.5 Rear Drum Brakes CBAP Straight Back Bench Seat CKAS Carpets - Floor and Cargo Area CSRS Passenger Assist Handles CUMS Mini Floor Console DBBC All Manual Transmissions DDX 5-Speed HD Manual Transmission DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle EAAC All Engines GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GFDA Rear Sliding Window GNAS Rear View Day/Night Mirror GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAAS Instrument Panel JAYA Instrument Cluster w/Tach JCAS 85 MPH Primary Speedometer JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAS Cigar Lighter JKBS Inst Panel Mounted Hood Release LAFS Key in Ign/Seat Belt Warning Buzzer LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MBJS Black Front Bumper MB1S Black Front Bumper MDAP Front License Plate Bracket MFGS Body Color Headlamp Bezels MHAS Black Windshield Moldings MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMKS Body Color Drip Trough Molding NAAS Federal Emissions NBKS EVAP Control System NDAS Catalytic Converter NMCP Heavy Duty Engine Cooling PB3 Intense Blue Pearl Coat QB3S Intense Blue Pearl Coat RAAC All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCDP 4 Speakers SBAS Power Rack and Pinion Steering SCES Alcantara Wrap Steering Wheel SFDP Front Extra HD Shock Absorbers SGDP Rear Extra HD Shock Absorbers TAAC All Tires TBBP Full Size Spare Tire TBMS Tire Carrier Winch TRNA P225/75R15 OWL Wrangler AT Tires WJDS 15X7.0 Styled Steel Wheels XBSS Pickup Box XEAP Tow Hooks XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Link to comment Share on other sites More sharing options...
Jeepman Posted July 25, 2011 Share Posted July 25, 2011 The HD for your year would have been the AX15 But post up your VIN and It can be checked to see Link to comment Share on other sites More sharing options...
Geonovast Posted July 25, 2011 Share Posted July 25, 2011 Or just get under it and look. viewtopic.php?f=9&t=11699 Link to comment Share on other sites More sharing options...
Eagle Posted July 26, 2011 Share Posted July 26, 2011 The HD for your year would have been the AX15 But post up your VIN and It can be checked to see There was no "HD" for the manual transmission. 1989 was a mid-year change from the Peugeot BA10/5 to the AX-15. Early 89's got the Pukegoat, late 89s got the AX-15. Just have to crawl under and see which it is. Link to comment Share on other sites More sharing options...
Jeepman Posted July 26, 2011 Share Posted July 26, 2011 The HD for your year would have been the AX15 But post up your VIN and It can be checked to see There was no "HD" for the manual transmission. 1989 was a mid-year change from the Peugeot BA10/5 to the AX-15. Early 89's got the Pukegoat, late 89s got the AX-15. Just have to crawl under and see which it is. No $#!& the AX15 is Not a HD transmission but it is if you compair it to the BA/10, Chrysler Distigushed between the two By Saying "DDX 5-Speed HD Manual Transmission " to identify between the two transmissions to make you feel good... Link to comment Share on other sites More sharing options...
