My junk is leaking fuel from the wires going into the fuel pump. Fuel pump works fine, I just need someway to seal the rubber terminal boot or get a new 'whatever' (I don't what its called, the circle thingy with the metal tubes and the wire connector holding the pump in the tank). I don't see anything on the Rockauto catalog, just pumps, o-rings, and lock rings.
Maybe this has something to do with my gauge not working.
if i remember right there is a o-ring behind the wires.you'll have to take the assembly out of the tank to fix it.new sending units aren't available for the mj either and cherokees are different than mjs.
Knowing is half the battle, thanks :thumbsup: Will probably need a new lock ring gasket too. Rockauto has one for 4 bucks.
Anyone know of a gasoline proof sealant or epoxy?
