RDAN1 Posted July 5, 2011 Share Posted July 5, 2011 Thanks to the advice I got last week from this forum, I was able to successfully disconnect my frozen rear brake hose line. Now I'm ready to replace it (plus the front lines also) with braided lines. I see many members have replaced their lines with braided steel lines but which ones are should I consider?.. I like the Crown lines I think but can't figure out if they fit an unlifted MJ as all the info talks about Cherokees but not MJ's. Like this one http://www.jeep4x4center.com/crown-indu ... -lines.htm All help and recommendations on this topic will be really appreciated. Thanks... Link to comment Share on other sites More sharing options...
Geonovast Posted July 5, 2011 Share Posted July 5, 2011 Have you considered these? http://kalecoauto.com/index.php?main_pa ... frdlsjoeg6 Link to comment Share on other sites More sharing options...
RDAN1 Posted July 5, 2011 Author Share Posted July 5, 2011 Have you considered these? http://kalecoauto.com/index.php?main_pa ... frdlsjoeg6 No. Never heard about them. What can you tell about them???????? Thanks Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 5, 2011 Share Posted July 5, 2011 I got a full set from Crown for a YJ, and they work great, are longer than stock for use when lift is added, and they bolted right in. The rear YJ line is not as long as a Dakota rear line, but is longer than the original. Link to comment Share on other sites More sharing options...
RDAN1 Posted July 5, 2011 Author Share Posted July 5, 2011 I got a full set from Crown for a YJ, and they work great, are longer than stock for use when lift is added, and they bolted right in. The rear YJ line is not as long as a Dakota rear line, but is longer than the original. Thanks for the info. Are the ones you got like the lines shown here for the 87-89 YJ's ??? http://www.jeep4x4center.com/crown-indu ... -lines.htm Link to comment Share on other sites More sharing options...
