littlezeeker Posted June 28, 2011 Share Posted June 28, 2011 http://fortsmith.craigslist.org/pts/2413639838.html i want dana 44 front and rear will any of this work for me ??? Link to comment Share on other sites More sharing options...
Automan2164 Posted June 28, 2011 Share Posted June 28, 2011 Anything will work with steel and a welder, question is, what is your comfort level? Rob Link to comment Share on other sites More sharing options...
littlezeeker Posted June 28, 2011 Author Share Posted June 28, 2011 i just want to know if i buy on of those d44 if i can change it to use my stock jeep wheels with out to much work and i got a torch and welder but not sure what i would have to do to make it work Link to comment Share on other sites More sharing options...
littlezeeker Posted June 28, 2011 Author Share Posted June 28, 2011 or will this one work ? http://fortsmith.craigslist.org/pts/2398979627.html Link to comment Share on other sites More sharing options...
Eagle Posted June 28, 2011 Share Posted June 28, 2011 or will this one work ? http://fortsmith.craigslist.org/pts/2398979627.html If I remember correctly, a Scout was a lot narrower than an MJ. And I don't recall what the wheel bolt circle was. Probably not a good choice. Link to comment Share on other sites More sharing options...
Incommando Posted June 28, 2011 Share Posted June 28, 2011 In the first post there is not a single complete axle assembly listed just various components. In the second the front end is disassembled and does not show axle shafts (that I saw anyway) in addition to the front being a pass. drop, meaning you would need to get a new transfer case for your rig to match that. Making front D44's work in an MJ is not the easiest of tasks. I don't know if a swap of this nature would be in my comfort level if my tech knowledge led me to consider either of those ads as potential parts for an MJ swap with the exception of the Scout rear. Even then Scout axles, like the popular Explorer 8.8 swap, are actually about 3" narrower than XJ axles (I am going from memory here) and may require aftermarket rims ( the bolt pattern is different than an MJ anyway) with less backspacing or wheel spacers/adapters just like the 8.8. Although much wider, the ideal donor set seems to be from a leaf-sprung Ford from the '70's. An f250 would also get you a D60 rear. They go for $400 + a set around here. The radius arm/coil spring F150 axles also work but require more modification to the front axle itself to remove/replace the suspension componentry or a modification to the MJ to use the radius arm suspension. Either way the set should be late enough that it has factory disc brakes, IIRC. Link to comment Share on other sites More sharing options...
SW86 Posted June 28, 2011 Share Posted June 28, 2011 i know a couple guys have the rubi 44 in the front. a swap ive been thinking about doing myself. don't know how much work it would be though Link to comment Share on other sites More sharing options...
Incommando Posted June 28, 2011 Share Posted June 28, 2011 TJ Rubi is bolt-in, JK not so much. There is debate over whether putting chromo axles and good u-joints in a HP D30 isn't better bang for the buck strength-wise than a stock low-pinion Rubi D44 as the Rubi which is rumored to be a hybrid with D30 outer shafts/bearings.etc..... Not sure that the Rubi 44 has the thicker axle tubes of some other versions, such as Wide-track FSJ's or 3/4 ton vesions, either. Link to comment Share on other sites More sharing options...
Garvin Posted June 28, 2011 Share Posted June 28, 2011 The first question should be what size tires you plan on running? The Dana 30 up front will hold up to a 33" fine in stock form. I was running 36" tires with wheel adapters and only managed to break the axle with doing stupid stuff. The rear can be swapping to a Ford 8.8 or 29 spline Chrysler 8.25. Both would need the perches welded on (the 8.25 needs the perches moved in). So what needs to be addressed first before looking at 3/4 and one ton axles is what size tires, what do you plan on doing with the Jeep (rock/mud/trail) and what is your driving style? Link to comment Share on other sites More sharing options...
