To pull my dash out nearly complete, I did the following:
- Disconnect battery
- Remove plastic Bezels and covers from dash
- Disconnect steering column harness, drop and pull out steering column
- Disconnect Dash harness at the firewall, the plug is held together with a 10mm bolt, and any door/kick panel feeds
- Disconnect/Remove TCU
- Trace and unplug HVAC vacuum lines
- Loosen but do not remove the 15mm support bolts at each A-pillar
- Remove the 10mm bolts along windshield and start to rotate the dash away from the firewall
- Disconnect vent plumbing and any other plugs you may have missed
- Remove the two 15mm bolts you loosened up, beware the dash is heavy and will fall to the ground
- Pull dash out and stick the bezels back on
