btm24 Posted June 22, 2011 Share Posted June 22, 2011 Would a 2000 XJ t case skid fit my 89 MJ? Also would it mader if I had a one inch rough country drop bracket for the t case? Thanks Brandon Link to comment Share on other sites More sharing options...
ComancheKid45 Posted June 22, 2011 Share Posted June 22, 2011 Yes it will bolt on and since the Skid bolts to the OEM cross member I don't know excatly how itll work with the drop, but it won't be hard 2 make fit either way i believe ;) Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 22, 2011 Share Posted June 22, 2011 Many people say that a tcase DB is not necessary on an MJ, the DBs were intended for the XJs which had shorter wheel base. On another note; think about this, when you use DBs to decrease your rear DL angle you are effectively increasing the front angle. IMO MJs don't need TC drops, stock is better. Link to comment Share on other sites More sharing options...
