Sway bar link lenght question..
In mid-1991 the factory sway bar end link length was changed from 7-1/4" to 8-1/4" on all MJs and XJs. If you have a small lift up to 3" you should use the longer end links to keep the sway bar end a bit farther away from the coils and orientated correctly. :cheers:
