Its a SWB tank?...
When I fill my gas tank past half tank, it leaks or parked with the front of the truck facing down hill. "fast dripping"
The guy I bought the truck from said its a bad seal...
Has anyone had this problem?
What am I needing to fix this leak?
I'm getting tired of paying $20 once or twice a week.
Its a SWB tank?...
For me that was my fuel sender unit having cracks and rust. Your fuel sender unit is located on the side of your gas tank where the fuel hose feeds in. You might be lucky enough (if you do not live in the rust belt areas) to have the gasket leaking, around the sender unit.
