fiatslug87 Posted June 6, 2011 Share Posted June 6, 2011 Would you still put a dab of sealant where the timing cover and block meet with the one piece silicone gasket? Link to comment Share on other sites More sharing options...
tbrand Posted June 6, 2011 Share Posted June 6, 2011 I did. Link to comment Share on other sites More sharing options...
Geonovast Posted June 6, 2011 Share Posted June 6, 2011 Always have, and the instructions for that gasket still call for a dap of RTV at all 4 bends. Link to comment Share on other sites More sharing options...
terrawombat Posted June 6, 2011 Share Posted June 6, 2011 Yep, put a small dab in each of the corners otherwise the oil will seep out. I usually put a small dab directly in the middle of the corner and then it spreads out when I torque the oil pan to spec. Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 6, 2011 Author Share Posted June 6, 2011 Thanks guys, just wanted to make sure there were no contraindications with doing so. The instructions are probably buried in the garage somewhere :dunce:. Link to comment Share on other sites More sharing options...
