Blue88Comanche Posted May 31, 2011 Posted May 31, 2011 Is there a way to test the load proportion valve to make sure it works right? or how do i properly set it up? the original stick rusted away and i replaced it with a wire coat hanger but do not know if it is adjusted properly... if you are looking at it the arm thing is at about the 10 o clock position. I am at work and did not drive the Jeep today, I wanted A/C, so if needed i can post pictures later tonight or tomorrow
MJRemi Posted June 1, 2011 Posted June 1, 2011 viewtopic.php?f=9&t=17968 This is a great post by Hornbrod regarding the load sensor.
