TCAR_Comanche Posted May 29, 2011 Posted May 29, 2011 would a fuel pump from a cherokee be compatible with a comanche?
mvusse Posted May 29, 2011 Posted May 29, 2011 would a fuel pump from a cherokee be compatible with a comanche? From the same era (Renix vs HO), the pump itself, yes. The sending unit/pump assembly, no.
TCAR_Comanche Posted May 29, 2011 Author Posted May 29, 2011 would a fuel pump from a cherokee be compatible with a comanche? From the same era (Renix vs HO), the pump itself, yes. The sending unit/pump assembly, no. thats the problem, i can't find a sending unit for a 2.5 l. no one has em anymore...any ideas?
Geonovast Posted May 29, 2011 Posted May 29, 2011 Sending units are the same between 2.5 and 4.0. They're not the same between XJ and MJ. I'm fairly certain XJ pumps are not the same as MJ pumps.
TCAR_Comanche Posted May 29, 2011 Author Posted May 29, 2011 Sending units are the same between 2.5 and 4.0. They're not the same between XJ and MJ. I'm fairly certain XJ pumps are not the same as MJ pumps. so i can get a sender for a 4 liter and itll work? cuz that would be great lol. ive tried everything from the ground behind the tail light, replacing the cluster , grounding the tank.
