littlezeeker Posted May 27, 2011 Posted May 27, 2011 http://store.4wheelingplus.com/proddeta ... 27&cat=199 or do you think it will be better to get this one http://www.rocky-road.com/xjcad.html or do if you can find something better please send a link thanks guys
SW86 Posted May 27, 2011 Posted May 27, 2011 screw that. save up/build your own long arms but yes they will.
Geonovast Posted May 27, 2011 Posted May 27, 2011 Any front lift/suspension parts for an XJ will work with an MJ. Rears are different, and won't.
Motion Offroad Posted May 27, 2011 Posted May 27, 2011 Any front lift/suspension parts for an XJ will work with an MJ. Rears are different, and won't. Not 100% true... XJ Control Arm Drop Bracket kits don't 100% bolt-up to the MJ's. The support braces on most of the kits (Rough Country and Rubicon Express) will not work on the MJ's due to the extra supports on the MJ's frame rails from the factory. With that being said we've had first hand experience with both the RE and RC drop bracket kits on the MJ's without the support braces and they've held up just fine. Also there are several longarm kits that won't work on the MJ's that were designed for the XJ's without modifications.
littlezeeker Posted May 27, 2011 Author Posted May 27, 2011 why do the front work but not the rear end parts ?
Geonovast Posted May 27, 2011 Posted May 27, 2011 Because the front suspension on an XJ and MJ is the same. In the rear, they use different leaves, different shackles, XJs are SOA while MJs are SUA..
littlezeeker Posted May 27, 2011 Author Posted May 27, 2011 ok how about bumpers do they mount the same as xj as they do on a mj
Motion Offroad Posted May 27, 2011 Posted May 27, 2011 ok how about bumpers do they mount the same as xj as they do on a mj Front - Yes Rear - No
littlezeeker Posted May 27, 2011 Author Posted May 27, 2011 ok how about lift kits are they about the same for mj and xj
