I've been having an off idle hesitation problem, checked the tps and it read 0.8v closed, and 4.65 WOT. I tried adjusting it but couldn't get higher than 4.8v. It does have a good 5v going to it. Would this be enough to be a concern and the tps to be bad? Also if this couldn't cause the hesitation, what else would be good to check?
Thanks!
Ps its the mj in my sig, renix 4.0
i had almost the same thing ...i reset the tps to .830 and cleaned [1.take the nut off with sand paper clean the loops off next coat the loops with never seize and no-ox with a star washer between the loops ..use of lock washer outside ]the the ground connection near the dip stick mount .. all ground connections cleaned/coated the same way ..now no more troubles
