"Blasphemy" Version 3.2
Stay tuned folks!
I know I have been off the radar for a while but I had to take some time for the house , fixing the lease return, prepping the 2002 stang for sale, deal with the RV write off (and find a new one), work things and whack of other $#it but I am baaaaack!
The goal in 6 weeks is to do
-weld on bead locks (ordered)
-cage reinforcement
-linked and coiled rear
-tranny pan repair
-exhaust repair
-www.browndogindustries.com motor mounts (ordered)
-maybe bigger tires
-u joint repair, batt relocation
-maybe a new winch (Kingone)
-Front diff skid plate
Who knows if I will get it all done but I am entered in the 2011 http://www.highriders.ca challenge and I want to come out with my Jeep in one piece. I will be calling in friends and favors on this one,...
Previous years photos,..
http://video.icq.com/video/video_selected.php?vid=y6hKsIO-Efw&icid=vr_rmpn
The first of the rebuild parts arrived,.. Weld on outer beadlocks and inner bead stiffeners from SUREWAY Metals in Calgary Alberta.
  Quote
Oh and box one of 2 from brown dog,.. but it was only the hardware :(
Tonight was supposed to be shop night but a massive multiple roll left a friend injured and his built Samari stuck 5hrs away (2.5hrs drive, 2.5hrs trail) at the bottom of a ravine. So 2 Friends from Chanda 4x4 in Calgary and I are taking tomm off to do a 2 Jeep recovery VS one Samari,.. supposedly its a bad situation. Oh and I had to borrow the Wifey's recently modded Rubicon to go so I have to be nice to it. Wish us luck
Everyone is OK it was a 19Hr recovery,... I will hyperlink the thread later,... Buuuut
I am so excited,.. more parts today today!
Motor plates and mounts from www.browndogoffroad.com ; review/build thread to follow
Now I learned the hard way wheeling an 4.0 block puts your mount bosses at risk and I almost destroyed my hopped up 4.0 because the bosses pulled off the engine. Spend the money on these if its anything from a DD to a comp rig!
If the product is even half of what their customer service, love for the sport/jeeps and overall knowledge is it will be one of the most beneficial mods to date!
Watch out for the review!
Browndog mounts arein started the 4 link
Start of the 4 link,.. Glenn helped me tonight and on 2.5 hrs we began,...
Stock XJ coil buckets:
Yes I am that "frugal" to reuse them,.. Freecycle anyone? :out:
Plasma'd that stuff down to size,..
Cut some brackets to "mock" up the stock XJ front buckets
I need to tack them in and test the ride height, then start the 4 link :)
Ask and you shall receive!
OK well today Stephanie reminded me the competition is 22 days away,..I guess I better get started on the 4 Link rear,...
Well my jay at Chanda had these kicking around on the shop floor so I figured they would be a good start,..
and plasma!
make some diff tube mounts
Quick test fit
made some upper mounts from shop scraps
and some uni-body reinforcements to share the load of the coils, the goal os to locate them right below the rear cage tie ins :)
Chassis cleaned up
been going for 2 hours solid , so time for a quick break!
  mj Mike said:
what type of coils, shocks & bump stops are you setting up in the rear?
I plan on using TJ front coils in the rear, as for shocks and bump stops :dunno: let you know when I get there!
A few more hours a bit more progress,...
Went to sit it on the TJ coils and the leafs got in the way so I cut the old tabs off:)
Full weight on the TJ spring only, leafs are there for alignment only
Well more repairs today,...
Exhaust and tranny pan met a few rocks last year,...
New one with a splash of paint
and in
My poor pacesetter header,..
Had to chop a section out :(
Got to keep plugging away 21 days to race day
  • 11 months later...
A few more updates,.. Sorry for the crappy pictures, just cycling the suspension with the lower links before we attack the upper section:
More to come,.. Still waiting on my damn tires
Got a bit more done tonight, only spend 3 hours on it but think I figured out the illusive 3 link,.. And no matter how hard I tried the d/s was out! So here is a rough idea on how it's going to look:
