manchemanche Posted May 24, 2011 Share Posted May 24, 2011 have a 2.5 4x4 4spd 1988 when not running you can shift trans in all the gears when running you can't put in in gear it will go into reverse but makes a grinding noise any help would be great I just picked it up last week this is my frist MJ love this thing Link to comment Share on other sites More sharing options...
tbrand Posted May 24, 2011 Share Posted May 24, 2011 How's the clutch? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 24, 2011 Share Posted May 24, 2011 :agree: is the clutch working, and how are the clutch and transmission fluid levels? Link to comment Share on other sites More sharing options...
Eagle Posted May 25, 2011 Share Posted May 25, 2011 If it shifts when the engine isn't running but won't shift when the engine is running, the clutch is NOT working. It's a clutch problem, not a transmission problem. Link to comment Share on other sites More sharing options...
zagscrawler Posted May 25, 2011 Share Posted May 25, 2011 you say it makes a grinding noise when in reverse or grinds when you try to force it into reverse? Also if you are on flat ground with nothing around you and start it up and try and put it in first gear with your foot off the brake does it try and creep slowly forward, i mean slowly? Link to comment Share on other sites More sharing options...
