Longer front brake lines
So not only do I need new front brake lines but i will need Extended Front Brake Lines for the 4.5" lift soon to be upfront. What all do I need? I know I need longer brake lines, duh, but how long? Should I go with stainless steel brake lines or is that not needed? I know rough country sells an extention "kit" (part # 89702) but I feel that I can order the same stuff thats in the kit for cheeper then the kit would be. Thanks
Brandon
I bought the 3 pk from IRO for $95 or $99 .
Frt- 27"
RR-21"
These are the plastic shielded stainless steel lines with proper ends .
Never got them installed just yet , but , if like the effect I got on my Grand Cherokee , SS lines do firm up the pedal and give slightly better braking .
They must have started making them longer,I helped a guy with an IRO long arm and his lines were a bit shorter then my chevy truck lines.
IIRC the chevy lines are a little over 25"
Its a bad pic but here is the 2wd chevy line next to a stock line
The part numbers are on my build page,they were about $25 for the set
