veritas4156 Posted May 16, 2011 Share Posted May 16, 2011 So apparently the reason why I pretzelled my drive shaft was because the yoke on the rear axle broke. Tab is missing and the u joint just slid out of the straps through there. Are there different yokes that were used on the D35 rear axles or can I just run down to the JY and grab one off any of em? Link to comment Share on other sites More sharing options...
mnkyboy Posted May 17, 2011 Share Posted May 17, 2011 I believe they are the same on all d35s Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 17, 2011 Share Posted May 17, 2011 You can use a heavy duty u-bolt style yoke like below. Much stronger than the standard yoke and just a few $$ more. Used one of these when I had to replace the pinion seal on the D44, along with greasable u-joints. Link to comment Share on other sites More sharing options...
veritas4156 Posted May 17, 2011 Author Share Posted May 17, 2011 More or less right now I just want to get the truck back on the road for as cheap as possible but when I lift it i'll probably switch over. Free is cheaper than anything so I'll probably take a stock one but it is off a YJ. Either that or fifty for a ZJ disc rear. If the gears are right. Link to comment Share on other sites More sharing options...
