Incommando Posted May 14, 2011 Share Posted May 14, 2011 Anyone have a diagram for the dash wiring or sound system wiring? The radio turns on and will change stations, etc... but I get no sound. This is a factory AM/FM/Cassette with pop-out controls for bass & treble. Oh, the PO had cut all of the wires from the plug into the radio instead of just unplugging it ( :fs1: ). I have the 13 or so wires correctly spliced back, but no joy... Thanks in advance Link to comment Share on other sites More sharing options...
hick92 Posted May 14, 2011 Share Posted May 14, 2011 are their good speakers in it Link to comment Share on other sites More sharing options...
maddzz1 Posted May 14, 2011 Share Posted May 14, 2011 http://www.the12volt.com/installbay/ste ... /1220.html Constant 12V+ Red/White Switched 12V+ Purple/White Ground Black Illumination Blue/Red Dimmer Red/Black Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Gray Left Front (-) Yellow Right Front (+) White/Red Right Front (-) Brown/Red Rear Speakers 4" x 6" Side Panels Left Rear (+) Gray/White Left Rear (-) Brown/White Right Rear (+) White/Black Right Rear (-) Brown Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2011 Share Posted May 14, 2011 There were wire color changes in 1991; corrected table below: Constant 12V+ PINK Switched 12V+ Purple/White Ground Black Illumination (-) BLUE/RED Illumination (+) ORANGE/BLACK POWER Antenna BLUE/RED Front Speakers 5 1/4" Doors Left Front (+) GREEN Left Front (-) BROWN/RED Right Front (+) VIOLET Right Front (-) Brown/Red Rear Speakers 4" x 6" Side Panels Left Rear (+) BROWN/YELLOW Left Rear (-) BLUE/ORANGE Right Rear (+) BLUE/WHITE Right Rear (-) BLUE/BROWN Link to comment Share on other sites More sharing options...
maddzz1 Posted May 15, 2011 Share Posted May 15, 2011 I was wondering if that chart was right, Don. It was listed as 90-92, I figured they might have changed with the HOs Link to comment Share on other sites More sharing options...
Automan2164 Posted May 15, 2011 Share Posted May 15, 2011 I was wondering if that chart was right, Don. It was listed as 90-92, I figured they might have changed with the HOs They did. Rob Link to comment Share on other sites More sharing options...
Incommando Posted May 15, 2011 Author Share Posted May 15, 2011 There were wire color changes in 1991; corrected table below: Constant 12V+ PINK Switched 12V+ Purple/White Ground Black Illumination (-) BLUE/RED Illumination (+) ORANGE/BLACK POWER Antenna BLUE/RED Front Speakers 5 1/4" Doors Left Front (+) GREEN Left Front (-) BROWN/RED Right Front (+) VIOLET Right Front (-) Brown/Red Rear Speakers 4" x 6" Side Panels Left Rear (+) BROWN/YELLOW Left Rear (-) BLUE/ORANGE Right Rear (+) BLUE/WHITE Right Rear (-) BLUE/BROWN This matches perfectly. Thanks! Link to comment Share on other sites More sharing options...
