Blue88Comanche Posted May 12, 2011 Share Posted May 12, 2011 How do I remove the Windshield trim... I would like to paint it but do not want to tape up my jeep and risk over spray. (I am still overly protective of the paint job i got last year) Thanks Link to comment Share on other sites More sharing options...
maddzz1 Posted May 12, 2011 Share Posted May 12, 2011 You need a special tool. There are clips underneath that you need to slide. Harborfreight should have the tool Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 12, 2011 Author Share Posted May 12, 2011 Do you know what the tool is called or looks like? Link to comment Share on other sites More sharing options...
maddzz1 Posted May 12, 2011 Share Posted May 12, 2011 Look here: http://www.buickperformance.com/glassremove.htm Link to comment Share on other sites More sharing options...
hick92 Posted May 12, 2011 Share Posted May 12, 2011 here's a site for auto tools this one will get you straight to the windshield tools http://www.autobodytoolmart.com/search/ ... ld%20tools Link to comment Share on other sites More sharing options...
flint54 Posted May 12, 2011 Share Posted May 12, 2011 And probably best if you go ahead and plan to replace those plastic clips. They're old and brittle. Team Cherokee does (or at least did) sell them. Link to comment Share on other sites More sharing options...
Boots Posted May 14, 2011 Share Posted May 14, 2011 I just used a cotter pin puller and/or screw driver, they come off pretty easy but are very brittle and like to break if you aren't careful. :wrench: Link to comment Share on other sites More sharing options...
NewfieMJ Posted May 14, 2011 Share Posted May 14, 2011 How do I remove the Windshield trim... I would like to paint it but do not want to tape up my jeep and risk over spray. (I am still overly protective of the paint job i got last year) Thanks You should still mask off the paint around the trim to prevent any damage , ie: scratches , while removing the trim :brows: . And double tape for extra safety ;) . Some clips are a pain . Slightly on topic , I wonder how hard it would be to convert to the new style XJ rubber moulding . I know I saw it in someones build somewhere , but not the process . Probably just a matter of trimming the tabs for the old clips . Thought I'd throw it out there if your not stuck on OEM . Link to comment Share on other sites More sharing options...
maddzz1 Posted May 14, 2011 Share Posted May 14, 2011 How do I remove the Windshield trim... I would like to paint it but do not want to tape up my jeep and risk over spray. (I am still overly protective of the paint job i got last year) Thanks You should still mask off the paint around the trim to prevent any damage , ie: scratches , while removing the trim :brows: . And double tape for extra safety ;) . Some clips are a pain . Slightly on topic , I wonder how hard it would be to convert to the new style XJ rubber moulding . I know I saw it in someones build somewhere , but not the process . Probably just a matter of trimming the tabs for the old clips . Thought I'd throw it out there if your not stuck on OEM . This is my plan when I replace my windshield. Link to comment Share on other sites More sharing options...
